Boost Gauge
Sekred
Installed a boost gauge the other day.
I was not sure where to put. I would of like it on the side pillar or on the dash but really loath to drill holes in things and glue/stick gauge pods to the dash area. In the end, I installed it in the centre console.
L
lessard.dcj
Thread Starter #2
good job, not sure why the car doesn't come with a boost gauge like the focus.
M
MJ1246
Very cool um, so when looking at the boost gauge while driving...
Sekred
Yes, that was a consideration. Looking down while driving is not ideal.
To counteract that problem to some degree, I have mounted the gauge on a angle so at WOT and max boost (around 21 psi) the gauge needle is vertical requiring just a quick glance down.
Administrator
Staff member
Reactions
Can you post a close-up image?
I was thinking about eventually getting a boost gauge as well and was considering putting one on the a-pillar.
Administrator
Staff member
Reactions
Yeah thanks, man that looks really clean. Were you able to tap into the existing wires to power the gauge or run your own from the battery?
Sekred
I have not wired it up yet but my intension is to connect directly to the OEM instrument dimmer control . I just need to have a close look so I can work out how the dimmer switch comes out of the dash.
Administrator
Staff member
Reactions
Maybe this might help if you decide to tap into the radios wiring:
2011 Ford Fiesta Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Yellow/Red
Car Radio Accessory Switched 12v+ Wire: Brown/White
Car Radio Ground Wire: Black/Blue
Car Radio Illumination Wire: Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Power Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): White/Brown
Right Front Speaker Positive Wire (+): White/Violet
Right Front Speaker Negative Wire (-): White/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Green
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Brown/Blue
Sekred
Thread Starter #10
Thanks MKVIIST, I may need to use that info. Dimmer switch is a no-go. Dash module uses its own electronic control unit, can't just add a gauge. [:(!]
Sekred
I change the gauge mounting background because the satin black paint was marking very easily.
This is where I picked up the boost and vacuum signal for the gauge. I tee into the only fitting I could find on the intake manifold just above the throttle body.
Administrator
Staff member
Reactions
I love it!
Sekred
Thread Starter #13
Thanks MK, I'm slow but methodical most of the time. Sometimes I lose my patience and stuff things but.
