- rome
- Non-US
- Italy
- ford fiesta mk7 1.25 82hp
Good morning, i have a ford fiesta mk7 1.25 82hp 2009, I bought it in September 2025 used with 25,000 miles, it did very few miles a year, I proceeded to do the routine maintenance and replaced the braking system with Brembo Xtra discs and Brembo pads, after about 1,500/2,000 miles I noticed that it was making more and more noise in the front area, I took it to several mechanics but I never solved it, I hypothesized it was the pins of the caliper support, I greased them and it improved a bit but it comes back, I suspect that it is the pads (as if they were slightly smaller and moved, in fact if I brake the noise does not), as a second problem these pads whistle, I tried to clean everything and put copper grease but it does not change, will the pads need to be changed with another brand?
Thanks everyone for the replies
