Fiesta s and se nitrous.
Mmmmmkay....use whatever you guys want but I ended up just getting a 5/16th OD high pressure fuel hose. The got a NX 5/16th barbed T fitting and clamped everthing.
My only concern would be to not have flanged ends on these tubes to retain the hose from slipping off. Don't know the fuel pressure there but over time, as the clamps seat into the rubber it will loosen the grip and the flange would provide some safety from the hose just slipping off the tube. Could be overkill, but I have experience with fuel hoses coming off and pumping fuel onto the hot manifold and it's instant fire with not much chance of putting it out before a bunch of damage is done.
Calebdrums1985
Saint peters
2014 fiesta s hatchback
Thread Starter #22
I'll be keeping a eye out for sure. Probably just needs to be routinely inspected which I believe I'll be doing once my systems ready to go. Making sure lines are tight and yada yada.
Calebdrums1985
Saint peters
Thread Starter #23
Got bottle gauge put on and filled. installed purge kit with everything wired. System works and purge is bitchin. Still need AF gauge, colder plugs and I'll be making hits. I'll get pics of wiring and video of purge.
Longview
2014 Ford Fiesta SE
#25
I’ve put off putting nitrous on my Fiesta as I have opted to save up more money to put a two stage kit on my truck.
Looking forward to seeing some results from your install.
Calebdrums1985
Saint peters
Thread Starter #26
Going for a 150 or 200?
Calebdrums1985
Saint peters
Thread Starter #27
Longview
2014 Ford Fiesta SE
#28
Two stages of 150 each is the starting point. Engine’s fully built for a power adder, so I’m throwing the juice to it for now. I may ditch that later for a Dyers blower setup.
Calebdrums1985
Saint peters
Thread Starter #29
Not familer with 2 stage im assuming to not trash the
Sounds like a beast what engine you got in it?
This is so kewl!
But I thought Nitrous was "vapor" - as in you went into the manifold vacuum port(s).
This one is fuel (liquid) - so does the "wet" contain a fuel or just the solution for the NO2?
Longview
2014 Ford Fiesta SE
#32
Dry kit is nitrous only. Wet kit is both nitrous and additional fuel. Dry is good up to 75hp, but I think 75 is pushing it a bit too much. I’d go with a wet kit no matter what just to be safe.
Lean is mean, but rich is safe. With the non-existent tuning capability of non-ST Fiestas, I’d advice to run on the rich side, run the best fuel you are able to obtain, and try out different temp plugs.
Edit: if you have any problem areas like older CV axles, aging clutch, etc… nitrous will make them worse in a hurry [emoji23]
Calebdrums1985
Saint peters
Thread Starter #35
I'll agree with the better to be a little rich than lean. To be on the safe side ill jet for 35hp first and check plugs. Do you think to be even safer I should jet the fuel for 50hp with the 35hp n2o jet? Or would this cause it to be to rich and nit produce the go its intended for?
Longview
2014 Ford Fiesta SE
#36
That was my plan. Run richer fuel pills and play around with that.
Calebdrums1985
Saint peters
Thread Starter #37
Hence why a AF gauge is super important. I'll size up the fuel see if its 12.5 or lower. Thats were I wanna be at full load. Anything above 12.5 im shuting down.
Longview
2014 Ford Fiesta SE
#38
I’ll be converting my truck to the Holley Super Sniper fuel injection next summer. I’m old school, but these new school systems can’t be beat. Love the endless tuning options. Having a car with zero ECU support has been frustrating lol
Calebdrums1985
Saint peters
Thread Starter #39
I honestly think the carbs be easier to tune. Better carb plate kit and id still go wet. Youd be able to retard timing easier.
Calebdrums1985
Saint peters
Thread Starter #40
Damn I keep forgeting these EFI kits for the carbed motors. Is ignition remain all the same
