Turn 2011 Fiesta TPMS light off using FORScan
jwtimmons
Edmonton
2011 Fiesta AT SEL
My daughters winters tires are on rims without TPMS so the tpms light is on
At your own risk you can disable the TPMS on the 2011 as follows
Run Forscan
Open AS BUILT for the VSM Module
On line 1 "755-01-01"
Change 8038 0000 0016 to 0038 0000 0096 (so changing the first digit 8 to a zero and the checksum changes from 16 to 96)
Write changes
Ignition off and back on should have you with no error light.
Use at your own discretion
