Traction control
Mercurios2011
Member
interlachen
2011 fiesta se 5spd
Morning and happy beginning of summer yall..
To keep it simple, came back from vacation, fire here up as usual make sure all is good before going back to work next day,and this what i got. Already check fuses and relays ,latee weather permit tear into the front end to look for nicked wires or maybe dirt stuck somewhere, before I even consider the module, any suggestions, thanks in advance
Mercurios2011
Mercurios2011
Member
interlachen
2011 fiesta se 5spd
Yes ,I need to go pick up my scanner too ..😅
Might not be a bad idea to check Fluid levels too.
Why? Brake fluid and Tranny fluid and their dirt and those solenoids - else if it was a bad wheel sensor - it would also set ABS and even Check Engine Light.
So this may be a output sensor related to the transmission (Speed sensor) or something in the kick-panels and their gargantuan connector headers...
Mercurios2011
Mercurios2011
Member
interlachen
2011 fiesta se 5spd
The system was bled when I did the clutch pedal and same week later re bled the brake system, now I can really tell the difference on the hawk pads that been there for a min x)..
I just finished ,taking the abs sensor out and clean them,however i believe they are supposed to have a degree of magnetism, and non of em did at all.. least not where they pick up the read.
Before i even jump into module i will check into the trans sensor like you suggested, and if and thats big if comes down to that ,I have 2 options re flash the car and turn off traction from the pcm or get a race module which essentially does the same turns traction control off x'D , I don't mind not having it ,is the dam light on the cluster that bothers me..
I have the same issue on a 2010 Expedition and that has all wheel bearings replaced, steering sensor, and the module as well ,all fuses are good and relays ,it pull the Rv with zero issues, cruise control works and breaks flawless, but the damn cluster looks like a Christmas tree,abs ,brake,tc and now faulty TPMS 😒, I did read somewhere that sometimes a worn out rack may cause it too ,but that thing is solid from end to end..so idk
Mercurios2011
Mercurios2011
Member
interlachen
2011 fiesta se 5spd
I however order a new scan tool that supposedly reads abs systems in dept as well as other modules ,we will see what we can learn from it ,I'll try post a video once i get it hooked up ,maybe help someone else in the future
To turn on the TRAC Control light - the logic to the ABS or from the ABS to the PCM is being determined to corrupt.
The Word - "Corrupt" is left open for interpretation - as in what or where in the modules is this determined?
So to me this just might be more of a wiring or poor ground issue where the harness - the socket and plug at the ABS unit - or a ground bond point for it is bad. There is also the opposite effect - poor power delivery can also have an impact on this condition, as in not enough power so the signal sent and the signal returned are compared and noise is found - so it thinks its' corrupt - it can't analyze noise - but it can certainly see a loop return and know the difference between clean signal and poor signal - so I can see where "Corrupt" can be used to tell the tech that something is wrong - you need to fix it, I can't.
Got any way to backprobe the harness? IF it's not the fuse, remember the Fuse block itself then routes that power TO the Brakes - and also from that Brake Module - the power goes to the speed sensor (Speedo).
Why am I saying this? My car - is also having issues with the Oxides of March - which as seasons change the corrosion and oxides formed from it - are also eating at my wiring - especially in the Engine Bay - where my OEM battery had a top post seal leak and dripped - sprayed acid in and around the engine - so be aware of the Fuseblock and it is not truly sealed from the environment in the engine bay - it too does have issues with wiring off the crimped pinch-point spots where the Fuse is, not just FROM the battery or POWER side - but TO DELIVER power to the components from the branch that Fuse it's supposed to protect - not just Ground - Power feeds too..
You can find, that; as you drive - the ABS sill self test once you start to drive off, and if it has problems making the solenoids work right during that self-test check - BAM! - it sets the light on the dash...The issue of my battery and all those post-to-block to breakout adapters for terminals and all their internal fusing - helped me to track down some of those quirks - just offering my experience to you so you don't have to suffer like I did.
Mercurios2011
Mercurios2011
Member
interlachen
2011 fiesta se 5spd
As always is much appreciated.
So today i been working in the car since before 12pm had a tie rod to replace and finally got to the new toy lol.. even tho that scanner is update to 2025 ,i went ahead an baught a Creader 7 plus ,pretty cool i may say however, it read everything i already new ,but was able to read the abs snesor in real time driving and all of them pass. Took the abs fuse out ,put it back in and the ABS light stayed on till i started driving, within seconds turned right off.. with what you have shared and todays experience im leaning toward the abs module may be going bad, however a knicked wire somewhere very well could be the problem as well. Not to mention this car will be due for tires soon and while they are not bald ,i can sense a slight loss of grip at WOT ,hehe
Another thing that caught my attention was the yaw sensor giving arratic reading when tje vehicle was standing still and off!! It supposed to be zero..
That points me to a parasitic draw somewhere in the system.
My standing voltage on battery is little low ,engine off car sitting drops to 12.6 which points out the battery may be on its way out as well ,however 2 days ago it charged over night and was at 13v ..
I may just get a battery to completely rule power out, and go from there ,I been wating an AGM for this car anyway..
I tried uploading a video so you can see the yaw erratic reading ,but it canceled 🤷🏻‍♂️
Good to know...
When you mention "Yaw" I had a double take on that.
In light of my research, check your SRS bow (Bow meaning mounting and its location and the wiring to it) in the center console just between the Transmission Selector and the E-Brake handle - it's right under it.
When this sensor (the comparator in the SRS) gets goofy, it can be from many things up to and including a worn Rear Wheel bearing whose tooth to tooth gap where it makes the "tone" for the rest of the system is different from the others caused by the bearing hub and the tooth-wheel it uses on the speed sensor - their clearance is different. IT can change the signal level - gives s different tone or vibrates due to the bearing wear - generating a secondary tone effect that can make the system think something more is wrong but can't put it in a window of error codes that fit the condition.
Those tones then can make the system think one of the wheels may be close to skidding - but the overlying tone it gets proves otherwise so the TRAC light gets set. So a loose Hub to plate - dirty or failed sensor seal - or a worn hub - can affect the quality of the tone received, also inclusive is if anything spilled down into the central console well, and sludged up the connectors to the SRS unit - that level of interference can play a role in this too. So-o-o if you still have problems - dirt may be why.
Hypothetical of course, but worth looking into if you have not thought about those rear wheel hubs lately.
Mercurios2011
Mercurios2011
Member
interlachen
2011 fiesta se 5spd
I pulled the center console out and did not see anything other than clutch wire and shift cable 🤷🏻‍♂️,in light of what we have discussed and the fact that traction control is tied up to throttle response, i wonder if the front wheel bearings are simply worn out as well, they have never been replaced.
Plus im starting to have that dried out noise like older cars when their racks and suspension components whine and cry .
Mercurios2011
Mercurios2011
Member
interlachen
2011 fiesta se 5spd
The one thing that puzzles me the most ,the car was standing for 5 days , i just cranked it to warm it up and thats when it came on and stayed ..
Mercurios2011
Mercurios2011
Member
interlachen
2011 fiesta se 5spd
Well last week I finally replaced the battery with an AGM ,it was low crank low amps and the light still there,however when I was getting the car on a lift, I spun the tires lightly and the light flashed as intended. Almost as if the system is working even tho the light is on. At this point im almost used to seen it on.
Check your wheel bearings. The front hubs become loose and that will trip the ABS and TC mil.
On those struts, there is a small tabbed zip-tie clip - that holds the ABS wire fast to the strut itself.
Man, I feel for ya' = this sensor is where I got caught having to replace the harness due to similar experience with a Control Arm replacement mess I had to do just recently.
I had a dealership work on my transmission not too long ago from a broken part in the shifter assembly I couldn't fix - so it got covered under a warranty clause. Doesn't mean that they did it right-by-the-book. However, knowing how much of the vehicle had to be taken apart for that repair - raised a question about how it got tore up in the 4+ years AFTER I joined here...
  • (I never had to re-think how dangerous a bad-dealership mechanic can be until you have to fix something that makes you feel like it's loose or ready to fly apart) I had replace a lower control arm and that is how I find out they never properly tightened down the Left Axle spindle nut! You could easily remove it using a 3/8" ratchet wrench with little effort. It's supposed to be at 150 + lb/ft torque (188), you have to stand on the wrench rod using your body weight to make sure it's tightened. So it's not something than you can just spin off easily without serious effort or leverage.
Did that wire get pinched or pulled when working on any front suspension? It might help if you can get or try a new harness (or used - for swapping out troubleshooting) Mine got the outer sleeve protector wrap tore up pretty good, So I had to replace the wire harness which seemed to work for me.
I also learned too, that the sensor; although it's bolted in, doesn't take too kindly to getting yanked on when it's still on the knuckle. My sensor didn't crack, but I can easily see how others having similar ABS light issues after an axle touching-type-of-repair done by a shop can affect the integrity of the sensor which is what got me under my car recently to get that lower control arm job done.
