2013 Ford Fiesta Transmission will not shift into reverse
PatTech
Clinton
MS
2013 Ford Fiesta
I'm getting a indicator light relating to the transmission. The car will not shift into reverse. Once I turn on the auxiliary switch its like a the car can't detect whether or not the shift selector is in the park position before allowing the vehicle to engage the starter. Ford said that it sounded like a shift solenoid. Can anyone experienced this issue? If so please give me some advice. Thanks.
O-M-A-R
Stockton On Tees
Ford Fiesta 2008
Hi
I have a Ford Fiesta 2008
I have the same problem as well it doesn't always go into reverse the first time.
It might help if you follow these steps.
1. Pump the clutch a few times in neutral with handbrake on.
2. If it gets stuck in reverse change the gears a few times before putting it in reverse again.
Please note these solutions only fix my problems temporarily.
Also, if you are having troubles with your gears the problem may be with the clutch. Because my clutch is worn out and it is difficult to shift gears.
Thanks
