- Orlando
- FL
- United States
- 2012 Ford Fiesta
Hello! I drive a 2012 Ford Fiesta… A few months back I couldn’t figure out why the car was overheating. Started with small fixes and worked my way up. In the end the guy I went to changed the thermostat (3 times), cooling fan, water pump, radiator, and radiator hose. He also mentioned some sort of oil clog. Car ran great for about 3 months. Now I noticed once again, whilst sitting in traffic the A/C started blowing less cold and the high temperature warning light came on. Also the cooling fan would blow even after the car was turned off. It SEEMS like when the car is driving at a normal or higher speed the AC stays cold and the warning light turns off. Hitting traffic I had to pull over several times to let the car cool down. 3 mechanics have checked for head gasket issues and they all agreed that wasn’t the case. What is the culprit here? Another bad thermostat?? And if so what would cause 4 thermostats to go bad in such a short amount of time??
