Cvs20 purge solenoid
interlachen
2011 fiesta se 5spd
Good morning yall ,hope everyone is well.
So here goes, I'm either blind,dumb or stupid 🤣....
I be quick and simple, I can't find the location of this piece anywhere on the car, even at work says by canister ,other search Says front of vehicle 🤷🏻‍♂️.. supposed to be same part all the way to 2019..
I'm slowly changing all the emissions related parts as maintenance, since the car just turned 200K miles and would like another 200k out of it.
Anything helps and thanks in advance
Mercurios2011
interlachen
2011 fiesta se 5spd
Seem it was as I feared ,not all 2011 Have a vapor/charcoal canister removable solenoid some are built into it.
Low and behold here is the proof ,if you carefully look both canisters are for Fiesta but not interchangeable.
Any one that comes into my same problem now you know why you may not be able to find it. I LOOK everywhere under the hood took intake out,went under the car and even remove the RL wheel and fender to No avail ,then finally decided to turn the piece that most resemble and there is was a dummy plug, literally does,nothing as is sealed on the elbow ,and when you check the hole on the Canister is just that a hole 😅🤷🏻‍♂️
Excellent find!
So some valves are Integrated into the canister - so you throw it all away and get a fresh one.
The Valve exists, but due to Revisions that part may be "the same" but the solenoid is sealed into the canister so it becomes a replaceable canister not a solenoid ...
Since the Canister was redesigned - the New-Old-Stock (NOS) Solenoids are no longer in production - so it turns into a Where is ... As is .. scenario that includes the Canister it was used in...
WOOF!
Been finding this in other lines like Taurus and F-150's - the older EVAP solenoids the ones in the front, are now getting ported hole revisions - so the older revision stamped on the valve may not match the Revision and the hole part on the new EVAP valves - so that too can set and check engine light and with older revisions dropped from production - the Dealer / Service Agent has to re-profile the way the New valve affects the vapor pressures under a new porting and it's values.
Mercurios2011
interlachen
2011 fiesta se 5spd
hey Andy
I did not have C.E.L , as I deleted that code when the pcm was flashed and it was actually a dirty filler neck mouth ,had little bit of dirt , But the other day i was trying to fill up and the nozzle was acting up ,
8 out 10 times is that piece , plus the car just turned 200K and want all the emission components replaced before they actually fail, so i can focus on drivetrain maintenance , started with all tie rods these week
and next be rear shocks and move my way to the front , been holding on performance upgrades for a while now ,and now be even longer till who knows when [wrenchin]
