Before I cut it off…..
Edmonton
2014 Fiesta S
Ok the title is dramatic but I got frustrated lol. I am trying to remove my drivers side door panel(interior) and I have roll up windows…I wish a hot woman would fight to stay on me as much as the roll up handle…It’s a 2014 fiesta S, I’ve done some research and apparently there’s a retaining ring on there somewhere but I can’t see one and I also can’t seem to feel to hook it with a pick tools either….Someone have a solution here, I’ve been trying to get this thing off all afternoon.
Did you try to use a wet dish rag - damp - not soggy wet and wet with a light detergent - then just tuck the rag under the handle center - then gently roll it to see if the clip can be found and pulled off the post - using the towel to pull and then work off the clip.
Try this search in google...
Using a rag to remove a clip from a handle
Unless you've already tried it - I've had to do this myself to get panels off.
Get the right tool, it just pops off.
Looks like there's a clip in the rear.
The Ford Focus has the same style crank clip.
