Yet-to-be-named 2016 Fiesta SE
Tensioner?
Should have been replaced anyways as part of the cost - so this is a "cleaning" I too - don't appreciate.
As a delivery driver, I've seen many "kits" - these tensioners come standard in them so I don't know why that they needed a part separately - the parts required, usually come as a required condition of the repair - not optional. (They do have bearings in them and so that makes for a limited lifetime - so it's required.)
It's also why I like forums - for the participants leave behind their experiences like footprints to follow a trail to get to the destination - only the journey is a small book they leave behind for others to read - we all get a little smarter about it because of that effort.
It's getting to a point that Warranty is not a thing anymore to be used to enforce the shop to stand by their work, it seems more like a passing notice that you should do this, but it doesn't always mean it's required. That is the part I don't get, definitely fishy.
And also good to know that many a shop - to save time and turnaround costs - will drop specific items from the list as long as the main repair is completed - only that small detail can put you back into that shop to have them fix all their work plus repair the part that caused the fail due to it not being repaired/replaced at that time because of lack of time to wait for it to arrive.
It's like a time bomb they put in your engine - they have it set to go off, only you're not sure exactly when it will happen, only that it will and do you want to be there when it does?
Phil_F_NM
Philadelphia
2016 Fiesta SE
Thread Starter #83
I think the mechanic FILLED up my oil. I noticed today that my fuel mileage seems to suck, so I set to try to figure out why. No drips on the driveway, so it's not an obvious leak. The exhaust smells a little rich, so I pulled the spark plugs and the two plugs closest to the coil pack were bathed in oil. I also saw that two of my plugs were eroded down to the insulation, so I re-gapped them just to get by until payday then I'll replace them. None of the spark elements looked wet, but they were definitely unevenly gapped for some reason. Checked the oil and it's definitely full; I may need to pull out a few ounces.
I'm not sure about getting into injectors with this car. I have no problem on an old mechanically injected diesel, but this electronic whiz bang is a different beast altogether. I usually run a high octane fuel and have never gotten so much as a knock, but is it worth it? Is there anything I should run through the tank to clean varnish out of the lines and injectors? Is that even a thing? I miss my old carbureted Beetle and Corolla. Anyways, after I sort out the plugs (wires were replaced 18k miles ago) how else could I improve the efficiency of this car? Yes, I still need shocks, struts, and an alignment, I'm sure the latter would definitely help. But as far as the motor goes, anything else? Thanks all.
Phil
To have the exhaust smell rich - there are two types of "rich" in the smell - a type that means fuel enriched mixture or an oil-burner heavy odor type - can even leave smoke and a residue on the tailpipe.
The Fuel-rich means either unburned, (sour-stink of gas and leaves a residue of odor on your clothes.) or running rich (heavy burned odor of burned fuel like rotten egg smell from heavy acceleration onto a freeway on-ramp).
The fuel side, means injector problems - while oily odor ones means oil is getting cycled back into the motor.
Check the Dipstick - has to be UNDER that upper level mark - else it will suck in oil.
You did check the wires but so you know, the oil-soaking the wires may have gotten from the work being done, may have compromised their insulation - making them crossfire or even arc to ground - you may be able to see it in a dark room with the hood up and the engine running - to see if you can locate blue-ring arcs from the crossfire.
Did he add any additives? Might need a drive off and drive it out to drain out the tank.
Else, water or ethanol-gelled fuel in the tank, affecting the pump or what got thru; is in the fuel rail waiting to get pressed past the injectors to be burned.
Some have suggested that you unbolt that fuel rail box above the injectors and try to drain and clean out that box then reseal it back onto the injectors to see if the gelled fuel or dirt in the rail got flushed out so the injectors can take care of the rest.
Else use a HEET gas-dryer with Isopropanol based additive on a 1/4 tank of gas left in the car - to help thin out that gelled fuel to clear out the injectors and that fuel rail - for there is NO FUEL FILTER in the USA Fiestas past 2011 - for the pump itself uses a screen, but little else to hold back debris from getting into the fuel rail and it's plumbing.
If that doesn't help - it will need to have the intake and the injectors inspected.
Phil_F_NM
Philadelphia
2016 Fiesta SE
Thread Starter #85
No fuel filter!?!?! That's insane. I believe you, but I still think it's insane.
Thanks for the tips!
Phil
Found that out when they had to take apart a fuel tank in a fleet fiesta - no filter, it's a screen and to stand it off from the bottom of the tank - it uses a"shark-teeth" design in the bottom of the plastic housing to hold it up and keep dirt out of the way of the pump.
The canister itself may contain a media in a cartridge - but if it gets plugged, there is no way to change it - you have to change the whole pump.
  • Many may not understand this: look at this from a time and use standpoint. The pump being housed inside a container and it's float - suffer a lot of abuse from temperatures, vapor losses and pressures during those changes, as well as formulations, moisture and driving and that vibration and torque against the unit - places the assembly in a weaker state after such time. So it really should be swapped out for a new one.
Has anyone done a fuel pressure test on the pump? That may be all that it is. A plugged pump...
To Add:
The smell you get may smell like it's running rich, but it may be from Misfires, causing a wavering idle speed and hesitation.
So a plugged pump can cause a lean condition, making it smell like it's rich.
Phil_F_NM
Philadelphia
2016 Fiesta SE
Thread Starter #87
That's excellent information, many thanks!
I'm changing out my plugs today, then pulling a bit of oil out. I remember when I first got the car I had the same oil issue and you let me know about how the engine will pull oil into the combustion chamber if it is filled. Ever since then, I've been religious about my oil level and only after the visit to the shady mechanic, has the oil been topped. I may just do another full oil change since I don't know what got poured into the crankcase.
So, how difficult is the fuel pump removal? That replacement will probably be on the menu coming up in the spring, once the weather gets reliably warmer. I'll do it at the same time as my shocks and struts.
Until then, I'll run some Heet through the tank in an effort to clean the injector rail and injectors.
Thanks as always!
Phil
Just got done looking at several vids about how to do just that.
Why? Ever have a time when you needed to drain out fuel? O at least wonder why it can be running so rough?
You take out the lower back seat cushion and it will reveal a gasket that has wires running into it, that's the pump housing.
Pull it off...Look it over you might find a spare set of car keys from other people - possibly even road salts...mice, spare loose change you wondered where it went because it wasn't buried in the car seats...
Remove the electrical connector (pinch then pull).
Start the car a few times to pull out fuel from the line to help drain the line - pump doesn't have power now so it would be a good time to help it purge...using Injector and vacuum...
Might want to loosen - not remove the strap bolts to loosen the tank from the undercarriage - to give you room to loosen the locking ring.
Fuel connector - use a hook-pick to loosen the pinch points on that connector and bring towels to mop up.
A locking ring you turn counter clockwise to release from the tabs.
The ring turns - letting you lift, and push it aside - dropping the tank down - leaves room, so it slides away.
Gently pull - pry - and note location of tabs that seat the pump a specific way...
Pump lifts straight out - it's been immersed in fuel nearly all it;' life, so let it drain out back into the tank - the sender float usually goes to the bottom of it's stop.
  • so if it gets stuck look for where the float and it's arm are - it may have jammed against the opening - hence the tab/notch-seat orientation helps here...
Might want to inspect the tank and -if needed- siphon hose if you need to let the fuel drain and take some of it's debris out with it.
You can also see if there is any gelled fuel - shows up as blobs - sometimes of a darker different color - or since the tank is plastic and black - can often rest on the bottom as gooey rusty blobs - that's from the water in the fuel that got past the pumps own fuel filter. It can be sucked out - just can't use a motorized vacuum into a tank - but you can fabricate one using a bucket to hold the fuel before it arrives to the vacuum itself - like how they bleed brakes on a one man operation - you just have a bigger tank or bucket to do this.
The vid I found that does the best job of showing you how to do this is from the UK side - they're from those 1A Auto (Produced by TRQ) Auto clinic vids.
Phil_F_NM
Philadelphia
2016 Fiesta SE
Thread Starter #89
Again, many thanks for the fuel pump procedure, as well as everything else!
I picked up the iso Heet this afternoon and I'm just a hair below a quarter tank, so I put most of the bottle in; of course, the neck of the bottle isn't quite wide enough to unlock the little cap in the filler, so a bit spilled down the filler neck hose that collects all the potentially unwanted stuff and drips it onto the driveway.
Anyway, started the car up (it was already warm) and figured a few minutes would be enough to get the additive in the lines.
Tuned the car off, removed the plug wires, pulled the plugs and put in a set of new NGKs. The local Autozone had those (Iridium) for about as cheap as can be found locally. If I wasn't in a hurry to get these changed, I'd have ordered them online at half the price I paid, but they needed changing, so here I am.
Plugs got changed, wires cleaned and placed back on, then I started the car.
After a bit of warming back up, I noticed a regular noise. I think the #4 fuel injector (closest to the battery) is making noise. It, or something right there will audibly click at idle with engine rotation, differently than farther down the engine, then stop clicking. I got the stopwatch on this and started the watch when the clicking stopped. It took 14 seconds to begin clicking again, and 18 to get to full volume, would click for a few more seconds then stop, and the 18ish seconds starts over again.
I turned the engine off, disconnected the injector electrical plugs, cleaned them, then reseated them. Started the car up again and after a minute or so, the clicking resumed.
So, it's sitting now, soaking in a concentrated mixture of Heet and remaining fuel. I'll be picking up the wife in a couple hours, so I'll see if there's any difference in sound when I start it up.
If I need to change an injector, do I swap out all 4 or just do one at a time? Can they be cleaned? Tested? For 10 years I was used to mechanical injectors in my old diesel Benzes, I had a few sets rebuilt and matched over the lives of those cars. Are these little gas injectors at all similar? They look like electromagnetic/mechanical switches, more than injectors.
Anyways, thanks for all the info, as always!
Phil
Phil_F_NM
Philadelphia
2016 Fiesta SE
Thread Starter #90
Ok, the car has had two warm-up cycles and an overnight soak with Heet in the tank, lines, rail, injectors.
And at idle, it is SUPER QUIET.
Regarding the cyclic ticking I mentioned in my previous post, that may actually be the tinnitus reducing wave setting I have built in to my hearing aids. Whoops. It has a noise cancelling waveform which cycles about once a minute, not unlike what I thought/think may the fiesta engine.
So it's quieter, which is nice. Hopefully that points to more efficiency and better fuel mileage, we'll see. I still need to do an oil change, I think, but when I pulled the plugs yesterday, none of them had any oil around the threads or the hex flats.
When I do that next oil change, what is the consensus on additives? I still have a bunch of stuff from my diesel days, a can of which is some LiquiMoly molybdenum disulfide oil additive. Should I add it? Is there any reason to do so, or not to do so? I've been running Mobil 1 5W-20 a long with good filters, for my ownership of the car.
Now that I'm past the hump of the timing belt change, I'm hoping to get another 100,000 miles out of her and want to do what I can to effect that. The engine in my first W123 Benz had over 400k miles on it and was running strong when it and the transmission decided they wanted to be in another car with less rust. That reminds me that I need to wash this car soon.
Phil
There are ways to clean injectors - using the fuel rail and the injectors installed on it - but do you need to? That is a personal choice.
Better to give the HEET (Red bottle) some time to do the job while everything is still mounted to the car. I have a fear that once more parts start coming off, the more problems you may encounter.
Do not overdo the HEET additives, or any additives at this time, for they may cause bigger issues with the dirt and gunk, now loosened, further damaging or getting thrown into the cylinder to be ground up. Which on the surface may be a good thing, but remember the debris in there - may stay a while and work down the cylinder walls leaving a scratch or two on the walls while it works its way down past the rings into the pan and then maybe trapped by the filter - else it will just lay there not doing much except being a threat later.
There are several methods - but once again, the issues are around the injectors and their seals. Which this may make them reveal you have a seal leak...that would be a different problem but solvable - and something that can be done by yourself if you're up to it.
Phil_F_NM
Philadelphia
2016 Fiesta SE
Thread Starter #92
If it's not one thing, it's another...
Back in the second week in March my per diem healthcare job way, way out in the burbs decided not to give me more hours. That day, on the way home I was offered a job, then the following day I had a second interview for a different job that I took. Began working on March 31 and received my first paycheck a couple weeks later. Barely clearing bills this month, but we're still afloat, water is up to the gunwales though and another wave is going to threaten to capsize this metaphorical boat.
So, last friday I took my car in to the Toyota dealership where I bought it, for annual PA emissions and safety inspection (I, along with probably every other person not getting paid by this pay-to-play system have severe criticism of the inspection system and the process) and I passed everything except...
The suspension.
They failed me on leaking shocks and a control arm needing replacement. I knew about the shocks, but not the control arm. The backstory is that last year when I did the inspection at the Toyota dealership, I asked if they could do the work on the suspension and when the timing belt needed it if they would do that work. They told me to take the car to the Ford dealership, which I thought was ridiculous. Anyway, we know how the timing belt kerfuffle went, car is running well, only that now I need to replace my shocks and struts, as well as a control arm, then get my car back for reinspection.
So I'm back on the bicycle, doing a ~12 mile commute to and from work. Rent is coming up in a couple days, so this paycheck I'll be receiving on Friday is not going to the car. I might be able to get a pair of Bilstein B6 shocks for the rear, but those struts and the control arm are going to take a bit of saving up for, another paycheck and another two weeks on the bike and possibly the train or bus.
So like I said, if it's not one thing, it's another. But I'm thankful I'm capable of working and mobile; I have the ability to do the suspension and steering work, just need to be patient and keep pedaling.
Phil
Phil_F_NM
Philadelphia
2016 Fiesta SE
Thread Starter #93
Turns out that the car failed inspection on just the rear shocks leaking. The service desk guy at the dealership made it sound like shocks and struts. I just looked at the report to see about the control arm and it turns out only the rear shocks needed replacement. Those just got replaced with a set of Bilstein B6s. I don't have the B6 struts yet, that's another payday. The last inspection issue is that control arm, which I think is the left side which is faulty. How difficult is the control arm replacement on this car?
Thanks all!
Phil
Phil_F_NM
Philadelphia
2016 Fiesta SE
Thread Starter #94
Control arms got replaced yesterday. Easy-ish day.
On another note, for some reason the right side Bilstein B6 strut is almost never available for the Fiesta. Plenty of left side, but I've only seen the right side available twice for only a couple days each time, in the last year.
Phil
Phil_F_NM
Philadelphia
2016 Fiesta SE
Thread Starter #95
Anyone install a GMRS mobile radio in their Fiesta?
I ask because I've got this good Nagoya dual band VHF/UHF antenna I want to use for a 50W mobile transceiver I want to mount in the car. My concern is that the Fiesta is a computer on wheels and I don't want my radio to be interfering with anything on-board the car. I'm not sure how various control modules are shielded from RF interference. Is this a concern I should even have?
I had the crazy idea the other night to find a more suitable vehicle for said radio and we just looked at a nice Honda Pilot, but the dealership wanted more of a cash down payment than we're willing to fork out. Anyway, I'm thinking of where I'd actually mount the radio in the Fiesta, and before that, wondering if I should have concerns regarding RF interference messing about with literally anything inside the computerized control bits in the car. Many thanks y'all!
Phil
Phil_F_NM
Philadelphia
2016 Fiesta SE
Thread Starter #96
Got the evap canister purge valve replaced last night and that finally allowed me to clear out the code. Car is back to more confident use. It had begun to get really hard to start after filling up the tank, and I think if I let it go one more time, I'd be having to wait a while, lest I burn up the starter.
I also got the aforementioned two-way radio installed. It's a BTECH GMRS 20-V2 and it's really small, perfect for the Fiesta. I mounted the cradle over the back seat cup holder, tucked in the power cable underneath, and used the 12v DC plug for power. The antenna is a very strong magnet mount sitting atop the roof about 6" inboard from the left weld weather strip, and 6" in front of the hatchback itself. The wire was snaked down alongside the hatchback weather stripping to about the 8 O'clock position then looped inside cabin, tucked under the interior plastic, under the seat back and under the seat base where it meets the radio unit in the cradle. The mic handset is also the controller with everything there. It works fantastically, no RF interference with anything on board.
Here's my mounting scheme for the radio and the magnetic base antenna:
Yes, the car is dirty inside and out. Winter is coming to a close and we'll be getting a really good clean going this next weekend.
Next up for the Fiesta will be a roof rack. Not sure which one to get and I haven't seen many for that matter. I'm not looking to carry a heavy load on the roof. Usually two bicycles would be the cargo, but I'd like the ability to hold a small amount of stuff up there.
Phil
Phil_F_NM
Philadelphia
2016 Fiesta SE
Thread Starter #97
Actually, next up will be changing out the struts and doing the brakes. New rotors, pads, drums and shoes. I'll be doing the front brakes while I take care of the struts since everything will already be apart up there.
What availability is there for stiffer sway bars for the SE? I think reducing a bit of body roll (which isn't bad) would be cool. I don't know if I'll be going with wider tires ever, but I like a stuck-to-the-ground feeling.
Phil
I just recently re-did work that a dealership did 3-years ago. CV Axle work they did, but that is a long story for later - I hope to be around here to help you get answers when you start this.
As far as the bar itself? That 3/4" steel - so unless it's been tore up by dragging it - the bushings usually are what are needed to be replaced - far easier than replacing the bar in swapping anyways (since those bushings will have to be done too at the same time).
Now if the holes to the links on both sides are elongated due to loose hardware and fasteners that failed - new links are also needed too when you replace that bar. Else that noise and drift will continue.
So when you have that thing up in the air, check your lower control arm - you may need to have it replaced - cheap insurance since you're going to be replacing stuff down there anyways. A lower ball joint having too much wear generates clearance and that results in shakes making the wheel feel like the cars unstable - forcing you to slow down - the lower control arm may be most of the reasons for this problem. Replacing it just might solve a lot of issues.
Phil_F_NM
Philadelphia
2016 Fiesta SE
Thread Starter #99
Tomorrow is another attempt at removal of those 18mm nuts that hold the struts to the knuckles. A few weeks ago, I made an attempt and broke a socket adapter attached to my breaker bar, so I replaced the rotors and pads and called it a day. I rotated the tires and noticed that I had a leaking valve stem, so I got that replaced. I'm not sure the wheel got balanced right because I feel a vibration in the front left wheel at times. Either under gentle power or coasting there's a noticeable feeling tied to wheel rotation, I'm pretty sure. I checked the CV boots and they are intact, CV axles don't have any play other than the bit of side to side they are supposed to have. Next time I get some cashola (we just put down money on a house, so spending is on a hiatus) I'm going to replace the gearbox lube. I did it once when we got the car in 2022. We've put 20k on the odometer since then. Keeping fingers crossed that everything is good. Wish me luck with these struts.
Phil
Phil_F_NM
Philadelphia
2016 Fiesta SE
Thread Starter #100
New struts are in. As well as sway bar links. The old strut bearings were shot. Really loose and probably where a bunch of my rattling was coming from. The driver's side strut was bent! I'm wondering how much uneven tire wear I've experienced because of that. Took it on a fast highway drive then some slower roads with turns and seeing as this is Philly, surface streets with all the bumps and potholes. Everything feels tight and the steering is so very light now. I'm willing to wager both struts were bent but I saw one that was noticeably wobbly. Anyway, I've got the state inspection in two weeks and need to get new wipers but otherwise I think it's great.
As for those sway bar bushings. I didn't have a wrench that could get in there, so that's work for another day.
My back is shot, I'm finding out. I found out this afternoon that the battery for my impact wrench is dead, faulty dead, so I did all this using armstrong power and tomorrow I'll be achy, I know.
Phil
