Leaking oil
Nathan
Port Elizabeth
South Africa
Ford Fiesta 1.6 2005 model
Hi guys can anyone maybe advise me where this oil might be coming from my Ford Fiesta 1.6 (2005 model ),thanx in advance
Given the vehicle age, I would start looking for some weeping around the base of the camshaft cover. You might want to have a look from underneath the car to see if the oil is also wetting the side of the engine block there also.
The Filter is Champion - as I do my research, Champion Filters - - well - er, it may not be the right one!?
Here's why...
Note ths size - pretty much will fit there but note the Thread size...
Now, Wix also offers a fitler 51516XP - which is similar except for Thread size...
But since you do not have the oil cooler - this filter would BARELY fit - the height of it makes it's pretty close to the radiators fan.
But this one a Purolator would fit the Champion Footprint and outline...but there - again - is a catch
Again - thread size. Uses SAE versus Metric.
So that's why I bring it up - your leaks may be from a front engine oil seal - or the filters own threads getting into this mess.
So you know, I am working with Ford Fiesta 2005 - 1.6L per your profile.
