IF you haven't investigated already, the Cabin Air Filter - can get plugged,
Tree leaves and Nuts
Bird nests,
Mice and or Rats
Squirrels
Pollen
Volcanic Eruption
s
Heck - even following an old 1976 AMC Pacer
r
can plug up the Cabin air Filter
FAST with particulates from these hazards and more - lessening it's ability to even suck air in...
So this Video - it may help...
Minor disassembly is required, keep track of all the hardware and where it goes and take pictures if needed - and reassemble once the air filter is been changed - or if you don't really care and just want to breathe air - the filter can be left out until you can get to a place to refit replace it as needed.
The Tools I needed to do my 2018 are a simple Phillips head - small fat blade screwdriver and a Torx #15 to remove the Torx screws to get at and remove the cleaner "holster" - once you got that cover off, remember if it's filter is REALLY Plugged, you might have to remove the outer windshield wiper cowl assembly to remove enough of the debris to free up the filter to get it out - not fun.
