fiesta mk8 remote locking
newbury
2017 mk8
3 door, drivers door remote locking unlock okay but the passenger door does not, can hear click by lock when using remote fob. it will lock unlock manually okay. any thoughts thanks
Even pressing the unlock function 2X?
One press unlocks the drivers side - but two presses should unlock all
Then double check when you're in the car, when the engine runs, when you open the Drivers side door, can someone, from the outside; open the passenger side door? Then try with Engine off; by, on a separate attempt (Restart close all doors drive until auto-lock engages then re-park back at the spot) turn off the engine, stay seated - but open the drivers side door, and see if auto-unlock for the passenger side occurs.
If not you'll have to dig around in the owners manual and find the spot for Child Safety and restraints - this sounds like a sensor in the passenger seat is either activating or not sending the proper (un)occupied signal to allow all the passengers to exit immediately. There is also a programmed feature to unlock all the doors from the keyfob - that is set to memory when all the doors are unlocked and you press both lock and unlock together and hold until horn sounds/marker lights flash or both - then try and see if the unlock for both sides occurs on the unlock single press works.
