Bonnet stuck
davesd1
Exeter
UK
2009 Fiesta
Hi All,
Could anyone advise me on how to get the bonnet to lift, it's a 2009 model. It's opened to reveal the lever, but it's totally solid. The cable now longer seems to play any further part. I can see what seems to be 2 x 10 mm bolts through the gap. If i removed these bolts would it allow the catch to lift with the bonnet?
I need to lift it as the oil warning light has come on.
Thanks in advance for any help in this matter,
This may seem counterintuitive, but the catch is possibly stuck with the opening pressure - so the latch can't budge further.
Have you tried pressing down on the hood to release the tension on the catch to see if the sprung hinges can then give enough so you can release that catch from the pawl?
I say sprung because if it has not been opened in a while and some impact or bump has deformed the front nose to the hood aspect - the hood is possibly caught in the latch itself as the pressure from popping the bonnets hood release then let the tension release and as it released that built up pressure it sprung the hood forward, and the front nose didn't rebound - so the latch is "stuck" under the hood (bonnet)
D
davesd1
Exeter
UK
2009 Fiesta
Thanks for reply Andy. I have read somewhere about pressing down, but i was worried about it completely closing and leaving it in a worse position than before. I may just place a packing piece under it to stop this from happening, then try pressing down
My thinking is, that i can still see these two bolts that may release the complete catch unit.
Might help if you can post some photos so we can help guide you...
Front of the Bonnet aimed at the catch would be the best help for then we can see where the tension, or broken latch is at.
D
davesd1
Exeter
UK
2009 Fiesta
Hi Andy,
I've dropped it down at a mate's garage to be looked at on Monday. I'll update it then.
Thanks for reply.
So you know, as you locate the problem. There may be problems with the rear pin hinges, there are two on each side, that help lift and tilt the bonnet (hood) so it can be lifted up and stay clear of wipers being to it's rear - being where the windshield and the wiper arms are - so it can lift over above and rotate the hood so it can get propped up...
So as you work on this, be sure to watch out for a pinch point on the rear of the bonnet so that then you're lifting, you may want to help "lift" the rear of the bonnet up; to allow those two pins on each side (parallel lift to allow the bonnet to rise up to clear the wipers and their arms) to get some space in-between them so they can allow the hood to continue to pivot up and open for you.
D
davesd1
Exeter
UK
2009 Fiesta
All sorted Andy. There is a scrap Fiesta at the garage so i removed the grille and had better access to the lock. Thanks again for your replies
