- Windsor
- Non-US
- Canada
- 2014 ford fiesta
How do I remove the wiring of the hatch (boot) door on my hatch back? I need to remove the hatch door to repair it. In order to remove the back hatch door first you have to remove the trim work on the ends of the car itself remove the rubber lining that goes around the trunk area then remove two holding clips they're the pushing type. Then you can gently pull down on the liner itself then you're able to disconnect the hose for the sprayer and the electrical wiring as well. I had to remove the push in wiring clip that's on the back side of the framework holding the wire and same for the hose putting it back maybe easier. Thank you all to who have answered and replied cheers
