- Grass Lake
- MI
- United States
- 2011 Fiesta SE hbk Blue
I was just cleaning up a front subframe out of a 2012 Fiesta and decided to take a few pictures of an install of performance type frame bushings on the stock sway bar. I have never seen an install with pictures due to the rather well hidden placement of these components. But it's really not that tough of an install if you are able to safely lift and support the car on Jack stands and unbolt the brackets from the subframe from the backside of the subframe.
Access to the left front asb bracket bolt is easier if you remove the left front wheel after raising the car onto Jack stands. The close proximity to the steering gear makes it easier to get at with a 13 M wrench from the drivers wheel well.
You don't have to disconnect the end links to do this upgrade to the asb bushings.
