Air con blowers not working - fiesta 2015
shd
UK
Ford Fiesta 1.0 Ecoboost 2015
Hi all
First post so be gentle with me please :)
I’m trying to resolve an issue with the wife’s car that has recently happened
To summarise :
She has a fiesta 2015 Eco boost 1 L petrol
Recently, the air conditioning blowers are not working whatsoever regardless of how low or high the speed is turned up
All you can hear is some mechanical noises from on the dashboard when the blowers are turned on
The lights on the climate control buttons are all working fine and the display indicates everything is working fine
I’ve captured a video but don’t think I can share it can I ??
Can anyone give me some pointers as to where to start looking, please ?
This is a UK edition vehicle and likewise we’re based in the UK but hoping there are similarities and synergies with other models worldwide
I’ve already checked the small rectangular fuses in the engine compartment fuse box with a multimeter and all are fine
There are some small square fuses that I have not managed to extract yet to test those also
Likewise, I’ve noticed there are some relays that again I haven’t managed to test as yet but plan to more of a case of a good overall health check of all fuses.
other than just checking all fuses on the electrical system, based on my description of blowers not doing anything even though they are turned up to maximum, Can anybody give me a pointer as to what is most likely cause please so I can be more targeted with my investigations?
many thanks in advance
Might need to grab the owners manual - it will help you find the fuses you'll need to check and possibly replace.
The AC unit itself has two types of motors - one for the blower that controls the air, the others - called actuators, handle the drum that rotates holes to line up and blow air thru those lines to the vents along with modulating the air temperature and intake from cabin or outside air sources - it makes a noise so that may be what you hear.
So if the climate control seems to work but no air - it just may be a bad fuse.
The Air fan - or blower motor is the one that uses a big fuse to handle the power and current to it thru a controller. Its easier to check the fuse for the air blower first - then if replacing the fuses (there may be a set you will need to check for even the controller has it's own fuse in a different location) and the blower won't come back on. Verify the AC works - you may have an issue with sensors that are supposed to keep the system from self-immolation caused by a faulty or stuck motor that can cause a bad smell or worse - a fire and burn up a wiring harness in the process.
