2015 SE Trunk Water Leak?!
Seattle
WA
2015 Fiesta SE
I noticed a pool of water in the spare tire well in the trunk of my 2015 Ford Fiesta SE. This is the second time it's happened. The first time I wasn't the one that discovered it so I assumed maybe someone spilled some liquid but the second time, I know for a fact that somehow water got in through a leak. The question is, is this a known problem on the Fiestas? Any ideas on where the leak might be coming from? I have a theory that it might be from the bottom as there is a small hole in the seal of the vehicle but if that's the case, then water should be able drain out. I haven't found any wet spots anywhere else or clues that it might be dripping from the top.
K
Seattle
WA
2015 Fiesta SE
No sunroof. It's just a standard hatchback.
Kitchener
2015 SE hatch
I had bad tape behind tail lights and fixed the leak with some aluminum tape...
That was 2 years ago.
Now my interior is getting flooded again. Small amount in truck, a large pool in rear seat footwell. Ugh!
