The Johnson stainless steel screen used for water removal treatment is composed of a V-shaped contour line and a longitudinal support rod. Every intersection of the V shape section can avoid blockage and ensure unobstructed water flow. The continuous gap has a larger opening area, which can reduce the speed of water flow into these welding wires, so that it has strong shrinkage and good mechanical properties. Avoid sand entering the screen under great pressure, so that the sand can be better filtered.
Wedge wire filter sieve plate specifications
Standard surface treatment: cutting the width and length of the flat welding screen
Optional surface treatment: deburring, degreasing and pickling, post-processing to obtain tighter tolerances
Material304, 316L, 2205, 347, 904L, etc
Length rangeUp to 6000mm
Width rangeUp to 6000mm
Slot range20 microns to 3000 microns (tolerance: +
Other shapesIt can be cut into any shape as needed, such as round, semi
Wedge0.5x1.50.75x1.51x21.5x22x32x43x5
Support rod1.5x2.5
2x31.5x2.5
2x31.5x2.5
2x31.8x2.5
2x32x3
2x4
3x5
3x6
3x10
4x72x4
3x5
3x6
3x10
4x7
5x63x5
3x6
3x10
4x7
5x6
5x8
Finally completedWith frame, without any frame, as required.
noteCustomized to the requirements
The function of Johnson wire screen
1. Stainless steel water well screens are used worldwide for the completion of water, oil and gas wells and environmental wells. It is the main screen type used in the well industry.
2. This screen consists of rods and warp threads. Rods can be round, triangular and trapezoidal lines.
3. Weld the metal wire to the rod to produce a rigid unit with high strength and light weight.
4. The warp line is a triangular line (V-shaped line), the well screen structure is reasonable, the opening area is large, and the slot size is accurate.
5. The well filter has the characteristics of heat resistance, corrosion resistance, good mechanical performance, long service life, safety and reliability.
Related Products
Packaging & Shipping
FAQ:
Are you a factory or trading company?
-We are a factory and have our own foreign trade team. We are professional in the production and export of wedge screens and screen plates.
What is the minimum order quantity?
-According to the MOQ of different products, sometimes the MOQ is determined by the customer.
Can you provide samples?
-We can provide samples for free, but the shipping cost is extra.
What is the delivery time?
-Usually within 3-25 days after receiving the deposit;
How is your sales service?
-We will provide each customer with marketing support and the best after-sales service, and help them get more new customers and orders.Customized Sieve Plate
website:http://www.jiashimachinery.com/sieve-plate/
Support rod1.5x2.5
2x31.5x2.5
2x31.5x2.5
2x31.8x2.5
2x32x3
2x4
3x5
3x6
3x10
4x72x4
3x5
3x6
3x10
4x7
5x63x5
3x6
3x10
4x7
5x6
5x8
Related Products
FAQ:
