Windscreen Washer Problem
Plymouth
2009 Zetec S
2009 Zetec S Windscreen Washer system not working when it is all connected.
The fuse is good, and the pump works when tested on a different battery.
I also tried a bulb in the connector to see if that would light but it did not.
When I test the connector that plugs into the pump it reads 11.5 V.
The confusing is; when I have the pump unplugged and I press the washer button, the windscreen wipers activate just like they would if the windscreen was just sprayed. However when the pump is plugged in and I press the washer button the windscreen wipers do not activate.
In short, every individual part seems to work fine, they just don't work when all connected.
Any ideas would be greatly appreciated
