We live in the USA so the P0606 error code may be serviceable because of our countries efforts to provide warranty thru watchdog agencies that help consumers.
Ford is aware of TCM failures, but if the dealer that sold you the car can inspect it, it may be possible to have the TCM fault fixed because they can replace the transmission and that module that powers it - thru Fords' Customer Service program and the known issues around recalled parts.
If you have time...try using this as a search criteria in your Google phone...
Code:
Ford 2013 Fiesta P0606 DTC code
Else, the only other suggestions are to clean up grounding points the vehicle uses to help return power back to the battery - also to improve the TCM's performance. The TCM shifts the vehicle using motors; solenoids and actuators in the transmission. They require power from the battery. So good electrical connection is needed. So inspect and clean battery terminals and any accessible electrical connections like those found at the battery can go a long way to help clear up this issue.
