Third brake light ?
Ashland
VA
2015 ford feista se
Is the third brake light in back window of 2015 Fiesta se sedan a sealed unit or can bulbs be replaced ? Thanks , any recommendation on part supplier for this piece
I believe that it’s an LED board. So “sealed “. I would recommend that you check the wire connections to confirm that it is not a damaged connection.
