Is the third brake light in back window of 2015 Fiesta se sedan a sealed unit or can bulbs be replaced ? Thanks , any recommendation on part supplier for this piece
Should be a LED on a circuit board by 2015. If you can’t find a bulb number in the bulb chart. It’s an LED. I would be checking the wire harness under the package shelf ( in the trunk compartment) to confirm that it’s still properly wired.
