- Nijverdal
- Non-US
- Netherlands
- Ford Fiesta mk7.5 St-line 2014
Sunday i was driving nothing wrong, i came of the highway and was slowing down and then when i kicked on the pedle to continue driving i felt it holding back and then shoot through that nothing wrong untill i was standing still it started with the orange wrench light, but couldn't go finally with a lil playing with the gass and. Got home and left it there, the next day i went through the garage, he had a simple obd scanner and it were two faults the gas peddle sensor and turbo charger. Initially i thought it was something with the coil packs since i had it with my golf 5.
He resetted the codes, but couldn't see a few because of his simple obd reader. After that nothing wrong no noises or warning lights but after a day of driving i feit it holding back a lil and from the third gear into the fourth is a little troublesome in the meantime i bought an obd reader myself which wasnt there yet. And the codes including the lights were back it was idling rough and spitting
So i checked the coilpacks and sensor to the turbo. Now i resetted everything again but its been a two days now nothings wrong no metal sounds when starting car is driving turbo is also nothing wrong, only from third to fourth gear is a little bad but always been i guess. But i think they'll comeback sooner then later
These were the codes before the last reset no reset after that and no codes yet. What do you guys think and what can i check now before ruling out its the turbo.
Thanks in advance!
Kevin
Verstuurd vanaf mijn SM-S918B met Tapatalk
Thanks in advance!
Kevin
