How-To: Fiesta ST License Plate Frame LED Bulb Replacement
Items Needed:
1) Small flat head screwdriver
2) 12961 LED Bulbs
Step 1 - Use the small flat-head and push back the clip and lift at the same time.
Step 1-B - If you have a hard time lifting it up, you can use a dull butter knife after pushing the clip in.
Step 2 - Remove the bulb housing.
Step 3 - Twist and remove the bulb from the housing.
Step 4 - Remove the old bulb and replace it with the new one.
Old bulb compared to the new LED Bulb.
Final Results.
A
alexanderfreenote
excellent and thank you very much for always posting step by step instructions!
M
mYsTiCfAc3
One weird question as im looking forward this mod but maybe using side panel type led
Is the socket vertical or horizontal when installed
If horizontal can it be flipped 180 degrees
No problem, glad you guys find it useful.
mYsTiCfAc3, the socket sits horizontal when installed, but its not flippable because there is a little groove for the clip.
See this picture
M
mYsTiCfAc3
i mean the bulb socket itself
ill go chek for myself ^^ ill take two minutes. edit: horizontal
and no need for canbus stuff right ?
Yeah no need, these are plenty bright.
I just realized we all have the same color ST lol.
M
mYsTiCfAc3
white FTW
I will order a bunch on ebay as trunk and map lights are the same
and when i looked at socket earlier I remembered your pictures and mine looked wayyyy more dirty
Hi MK, are you using a camera on a tri-pod and timer, nice work by the way.
Tripod with remote lol. Makes taking pictures so much easier.
