- Chicago
- IL
- United States
- 2013 Fiesta
Hi everyone I have done everything on this and other forums related to my problem.
My compressor is not kicking in. I filled the system with Freon, I checked the relay and fuse and I even replace them both, I replaced the low pressure switch and nothing, I check the connector to the compressor clutch with the multimeter and it displayed -14.00volts which I think it’s weird to display a negative reading I switched the pins and It didn’t display anything, so for sure I was in the right pin so I’m suspecting there is something wrong with the wiring of that connector even thought It was working perfectly 5 months ago. I bridged the clutch directly from the battery and it works amazing, cold air comes out from the vents right away. So what’s wrong? I know I don’t suppose to connect that directly but I’m desperate what else I’m missing?
