AP V3 issue with WOT
Location
kenosha
So I have a 15 Fiesta ST with a CPE exhaust and a mishimoto intake tube, when I installed the OTS Stage 1 91 it runs and drives fine until i give it WOT and then at like 4-5k It is like I am hitting a rev limiter.
Then I changed to the Stage 0 and it is doing the same thing, I had no problems like this before I installed the AP3 everything is updated on it, so I am seeking some advice.
Thank you
And I have tried this in second and third gear
Location
Metro Detroit
Well, the AP is a datalogger, take some logs to show us exactly what's happening. Upload them to datazap.me so we can all see what's going on.
Also, try uninstalling the AP from the car and verify the actual-stock program works correctly. It's entirely possible there's a file corruption.
worfab
Location
kenosha
So uninstalled and I can go WOT to 6k
Location
Metro Detroit
The factory programming should go to either it's 6,375 or temporary over-rev of 6,500 RPM.
I'd still like to see a datalog of the problem happening. IMO you should reload the AP. Make sure you do absolutely nothing while it'd flashing. Don't open the doors, fidget with the radio, nothing.
The default AP datalog settings should be a good start.
worfab
Location
kenosha
Reinstalled, still limits at 5k. Read that it could be a faulty clutch pedal switch, guess it is has happened before to people.
So i checked my ap and it goes from 50 to 100, never shows 0, going to try and get it replaced
worfab
Location
kenosha
All good, upper clutch limit switch came loose
