2016 Fiesta 1.6 Crank No Start
Owensville
2016 Fiesta
I have a 2016 with the 1.6 and 186,000 miles. It will turn over and has a spark at the plugs but it will not start. I've sprayed starting fluid in the intake and even tried a small splash of gas and it still will not start. I replaced the crank position sensor and the cam position sensor and even the coil just to be sure. I am wondering if it's slipped on timing perhaps? I don't think it totally jumped time because everything still sounds good when it cranks, it does not sound like the pistons have hit the valves or anything. I also checked relays and fuses, swapped in new relays etc and it made no change. Any ideas would be appreciated, thanks everyone.
