2011 Radio Failing
Charlottetown
2011 Fiesta SES 4Dr Hatchback
Apologies if already addressed, but I couldn't find anything specific to this issue. What happens is that whenever we drive for about an hour or so, the radio suddenly starts cutting out with a pop and then coming back after maybe 1-2 seconds. This happens regardless of whether it's AM/FM, CD, Bluetooth, whatever. We thought the CD we were listening to was skipping, but then we tried a bunch of them and finally the radio. The only way to stop it is to turn the car off for a while. However, you can even still hear the pop in the speakers when it's turned off until (I'm assuming) it cools off or whatever capacitor(s) discharge(s).
I don't want to spend hundreds of dollars on having someone prod around and tell me to replace the radio, as I've read a lot of people being told that and their own problems persist. I have experience with electronics, but not automotive setups.
I have not experienced anything like you have described. It should NOT cost you hundreds of dollars to have a Ford dealership technician diagnosis of the issue.
It could be a ground fault. It could be failed hard drive. Or maybe it is failing in some other, obscure way.
I can say that it is not difficult or expensive to replace the whole damn thing with another Sync system and control head from a salvage yard! Just make sure that you have the VIN and Sync radio I.D. numbers for the replacement unit. You will have to replace with the same sync level, no upgrade to sync3. Worst case, you should be able to have a functional sync system.
F
Charlottetown
Oh I didn't mean they'd charge for a quick diagnosis (poorly worded in the post). I've just read stories from other people saying they were told it was the radio, so they paid to have that replaced and mated with the car, and then the problem still persists. So then they're out the hundreds of dollars for doing that and still have their issue.
Maybe it is a bad ground, as the headlights will sometimes dim when I turn other features off and on and at least a third of the time this issue pops up it's preceded by a smell of hot electronics.
