Hello and welcome to our Ford Fiesta Forum community! Is this your first visit?
Register
See the top rated post in this thread. Click here
Results 1 to 5 of 5
  1. #1
    Medals
    Join Date
    Nov 2016
    Durban
    South Africa
    Posts
    Rep Points
    Ford fiesta aftermarket intake
    Guest-only advertisement. Register or Log In now!
    I am looking into fitting an aftermarket air intake on my 1.6 ford fiesta N/A. I see that there is a sensor connected to my standard air intake which i am told is called a (MAF) sensor.
    Could some one tell me what would happen if i fitted a simple intake system with out the MAF sensor as to if it would affect the car in anyway. OR would i be able to remove the MAF sensor and mount it onto the new performance intake?
  2. #2
    Staff Team Staff Team 20 Rep Points MKVIIST's Avatar
    Medals
    Earned First 5 Rep Points
    Join Date
    Jun 2013
    Tempe
    Posts
    1,129
    Rep Points
    20
    Most likely you'll get a check engine light appearing on your car since it won't idle correctly.
    Quote Originally Posted by kieranf97 View Post
    2014 Fiesta ST - 3M Window Tint, ESM Wheels, Bazooka Bass Tube, Rockford Fosgate Amp
    Want a free FiestaForum.org decal? Click Here
    Follow Us On: Facebook - Twitter - Flickr
  3. #3
    Senior Member 5 Rep Points Mike's Avatar
    Medals
    Earned First 100 Posts Earned First 5 Rep Points
    Join Date
    Jun 2013
    Posts
    188
    Rep Points
    Most intakes will have the proper hole to plug in the MAF sensor, why would you want to eliminate it?
  4. #4
    New Member 31 Rep Points
    Medals
    Earned First 5 Rep Points Earned First 25 Rep Points
    Join Date
    Feb 2017
    Jacksonville
    Posts
    13
    Rep Points
    31
    1 members found this post helpful.
    I would not remove the MAF. It has some functionalities that's why it is installed on our cars.
  5. #5
    Medals
    Join Date
    Aug 2017
    walworth
    NY
    Posts
    Rep Points
    Injen has a cold air intake for na fiestas last i seen.
Similar Threads
  1. Mountune intake review for my Fiesta ST
    By MKVIIST in forum Engine Performance
    Last Post: 01-13-2014, 06:52 PM
  2. Fiesta ST Intake Thread
    Last Post: 12-07-2013, 07:08 AM
  3. Sektune Cold Air Intake
    By Sekred in forum Engine Performance
    Last Post: 12-07-2013, 01:35 AM
  4. Any aftermarket access for this car?
    By cctman in forum Engine Performance
    Last Post: 10-02-2013, 11:10 PM
  5. Foam stripping around air intake vents
    By rweidman in forum Exterior Cosmetic & Lighting Modifications
    Last Post: 10-02-2013, 09:42 PM
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
