Ford fiesta stereo color code or diagram?
EZdusIt77
Does anyone know where to find the 2012 ford fiest stereo's color code or diagram? Any of the ones I find on the internet don't have the same wire colors as my head unit in my fiesta
Do you have the 4 or 6 speaker system? Can you elaborate what you want to do?
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): White/Brown
Right Front Speaker Positive Wire (+): White/Violet
Right Front Speaker Negative Wire (-): White/Orange
Left Rear Speaker Positive Wire (+): White/Green
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Brown/Blue
E
EZdusIt77
4 speakers with 2 tweeters up in the dash somewhere. I'm trying to connect my BTA8100FHC amplified BAZOOKA bass tube using the FAST9999 and FAST-BTAH harnesses that it came with
E
EZdusIt77
6 speaker. 2 in the back, 2 in front, and 2 tweeters. I'm trying to connect my BTA8100FHC amplified BAZOOKA bass tube using the FAST9999 and FAST-BTAH harnesses that it came with
E
EZdusIt77
I've already taken it apart and pulled out the radio, and put it back together. I'm gonna keep trying other wise the fast harness is a waste and throw more money at an inline convertor
Well in that case the speaker wires you want to tap into are the ones I posted above.
I would still recommend using a fuse tap for the Red (12volt) and Blue/White for the remote.
Just in case this is what I was referring to when I mention fuse tap.
Steve-0
This info is helpful, it is the same as the 16 right? im installing my 12 from my old car into this one with a scoshe loc, with remote base control. thinking about putting the amp under front passenger seat.
Yup it's the same.
Galion
I am installing one sub and I found this fourm to find the colours. I found them but one problem. The one one the right door "brown and white positive " is a bigger wire then all of them. The two on the left door are skinny brown/yellow and white/green. The wire on the right door Brown/blue is also skinny. But the brown and white is larger then all three of them. Right and left speaker wire https://imgur.com/a/elCjg
