2014 Fiesta speaker size?
MaNiAc_4LIFE
Thread Starter #26
Yeah I thought so cause I looked at the specs and asked him again so should I use #2 right which one would give best results
MaNiAc_4LIFE
Thread Starter #27
Also to add: http://www.rockfordfosgate.com/products/details/p1s2-10
You can see the different wiring diagrams I had spoke about earlier.
Just another thought
Can i run the four channels at 125 at 2ohms and bridge them to get 2 250 watt channels at 2ohms? Plus the 500 watt sub channel
And would this be a better amp or should I just stick to 2 separate ones?
Rockford Fosgate Punch P1000X5 1000 Watt 5-Channel Class AB Car Amplifier
RMS: @4 ohms: 75 watts x 4 channels + 200 watts x 1 channel
RMS: @2 ohms: 125 watts x 4 channels + 500 watts x 1 channel
12dB/octave Butterworth crossover
Short circuit protection
Over current protection
Infrasonic filter
On-board Punch EQ with +18dB boost @ 45Hz.
Muted turn on
Stealth top mounted control panel
High level input capable with Auto Turn-On circuit
C.L.E.A.N. Set-up - Helps ensure proper installation with minimal distortion
Optional remote Punch Level Control (Sold Separately)
Cast aluminum heatsink
2/4 channel switch
You can run the four channel on the door speakers.
I would not recommend getting the 1000watt amp, too much power.
A couple of changes.
On the door speakers you don't need something as powerful as a P600.
You can get a 400 watt amp and it will work just as good.
http://www.amazon.com/Rockford-Fosg...HZ6K/ref=sr_1_8?ie=UTF8&qid=1390833920&sr=8-8
The PAC line out convertor is cheaper and works just as good. It saves you money without having to get the RF converter and adapter. You'll also need two of these. One for each amp.
http://www.amazon.com/PAC-SNI35-Adj...WS3W/ref=sr_1_1?ie=UTF8&qid=1390834045&sr=8-1
MaNiAc_4LIFE
Thread Starter #33
The p400x4 will be enough for the components and coax?
MaNiAc_4LIFE
Thread Starter #35
the components are 100 rms and the coax are at 75rms thats each speaker?
and the amp is only rated at 50x4 at 4ohm so your the expert lol the P400X4 will be more than that i know cause RF is underrated would there be ANY advantage to getting the P600X4?
EDIT#1:And for the 4 channel amp do i just need to input rca front or will i need to use the rear input also?
EDIT#2:Would this be a better amp for my sub?
P500x1BD EDIT nevermind because
250 Watts x 2 @ 2-Ohm
means 500 total right?
When the speakers are rated at 100rms it doesn't mean you should push it to its limit. Its ok to have run a smaller amp as long as it provides great music quality.
I really see no advantage on the P600X4 over the P400X4 if you are using it for component speakers. If it matters to you then you can get the larger amp.
MaNiAc_4LIFE
Thread Starter #37
Okay thanks I'll probably go with 400 then
Sounds good, I just don't want you to end up blowing your speakers lol.
