Hello and welcome to our Ford Fiesta Forum community! Is this your first visit?
Register
Results 1 to 5 of 5
  1. #1
    Medals
    Join Date
    May 2018
    Forest
    VA
    Posts
    Rep Points
    Unhappy Radio stays on when engine is turned off?
    Guest-only advertisement. Register or Log In now!
    I have a strange problem with my 2014 Fiesta SE. Occasionally when I turn the ignition off, the radio continues to play and nothing can be adjusted on it. You can't turn it off by hitting the on/off button, can't change station or adjust volume. My local Ford dealer suggested disconnecting the positive battery cable for a few seconds and then re-installing it to get the radio to re-set. This works. However, the problem continues and I do not know the cause or the solution. Any ideas?
  2. #2
    Medals
    Join Date
    Aug 2018
    Waukee
    IA
    Posts
    Rep Points
    Did you find a root cause of radio issues
  3. #3
    Medals
    Join Date
    May 2018
    Forest
    VA
    Posts
    Rep Points
    Unfortunately I have not. The first couple of times this happened, it was in the winter when the outside temperature was really low. Then, it happened this summer, so temperature apparently is not a factor. If you discover anything, please share. Thanks for responding to my thread!
  4. #4
    Staff Team Staff Team 20 Rep Points MKVIIST's Avatar
    Medals
    Earned First 5 Rep Points
    Join Date
    Jun 2013
    Tempe
    Posts
    1,130
    Rep Points
    20
    It'll continue playing for about 30 minutes and should shut off by itself.
    2014 Fiesta ST - 3M Window Tint, ESM Wheels, Bazooka Bass Tube, Rockford Fosgate Amp
    Want a free FiestaForum.org decal? Click Here
    Follow Us On: Facebook - Twitter - Flickr
  5. #5
    Medals
    Join Date
    May 2018
    Forest
    VA
    Posts
    Rep Points
    My radio has played for over an hour when I have disconnected the battery. I have never tried to see how long it will play on its own. Guess I am afraid that it will eventually drain the battery.
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
